Dataframe layer masking - show data within
294
04-02-2012 01:36 AM
Status: Open
DietmarPalmetzhofer
New Contributor III
It is possible to define a certain layer as a mask for other layers in the context menu of the dataframe > Advanced drawing options, which is very usefull.
No data will be displayed where the area is covered by the masking layer.
Many times I would need it the other way round: Data should be displayed where the area is covered by the features of the masking layer.
E.g. when I want a layer to display only data within a municipality I have to draw a polygon with the size of the whole extent and then subtract the area of the municipality. It would be easier just to be able to use the polygon of the municipality (which commonly already exists) and say "display everything inside the polygon".
Tags (1)
2 Comments
KurtPfleger
excellent idea! I would have needed this very often.
SteveCole
And, if it's not explicitly clear, I'd like this feature to apply to rasters as well. Here is a figure that I have to create with some regularity where I am clipping a raster of land use classifications to a buffered polygon of a feature (land use within 1km of a wetland). Currently, I have to manually clip a dataset just to achieve this effect. It would be great if I could accomplish the same thing with a virtual mask based upon by buffered polygon.
