Default Geodatabase for a Map Template
346
08-23-2010 01:43 PM
Status: Open
JenniferBorlick
Occasional Contributor III
Currently when you create a map template and set a default geodatabase for that template, the default geodatabase is not distributed with the map template. I would like to be able to choose whether or not the default geodatabase is saved to the actual map template. I realize this might be problematic because the SDE connections are "user specific".
