File Geodatabase views should support domains
830
6
07-27-2023 01:27 PM
Status: Open
AJR
Occasional Contributor II
File geodatabases now support views (which is great), but the views can't have domains applied to them (this should be fixed).  If I have a view that pulls out a subset of data from a table and that table has domains applied to it, I should be able to apply those same domains to the file geodatabase view of the data subset, but this can't be done.  It makes (some) sense that views aren't editable, but since they are registered with the geodatabase I can't think of any reason why allowing domains to be applied to them shouldn't be possible.
6 Comments
SSWoodward
Thanks for the Idea, @AJR
Could you help me understand your desired workflow a bit more? Are you asking for the ability to edit fgdb database views? OR are you asking to see domain descriptions in the view as opposed to the domain codes?
Bud
A different take on this idea might be:
Need to access FGDB system tables using SQL. For example, provide a way to query for domain values (codes and descriptions) for a given domain.
We can do it in enterprise geodatabases like Oracle EGDBs.
What I do is create individual views to get the domain values (codes and descriptions) for a given domain.
The old way (EXTRACTVALUE has been deprecated in Oracle):
create or replace view d_atn_type as
elect substr(extractvalue(codedvalues.column_value,'CodedValue/Code'),1,255) as code, substr(extractvalue(codedvalues.column_value,'CodedValue/Name'),1,255) as description from sde.gdb_items_vw i join sde.gdb_itemtypes it on i.type = it.uuid, table(xmlsequence(xmltype(definition).extract('/GPCodedValueDomain2/CodedValues/CodedValue'))) codedvalues where i.name = 'ATN_TYPE'
The new way (using XMLTABLE):
select cast(rownum as number(38,0)) as rownum_, x.code, x.description, i.name as domain_name from sde.gdb_items_vw i cross apply xmltable( '/GPCodedValueDomain2/CodedValues/CodedValue' passing xmltype(i.definition) columns code varchar2(255) path './Code', description varchar2(255) path './Name' ) x where i.name = 'ATN_TYPE'
Then in a query/view where I'm selecting data from an EGDB table or FC, I join from the field that has the domain code to the domain view to get the domain description:
select
    objectid,
    atn_id,
    type as type_code,
    d.description as type_description
from
    infrastr.active_transportation a
left join
    infrastr.d_atn_type_vw d
    on a.type = d.code
But that's not possible with file geodatabases, since we can't access the system tables via SQL.
AJR
@SSWoodward - I'm not asking to be able to edit a file geodatabase view (although that would be nice), I'm looking to be able to apply domains to a file geodatabase view.  So in answer to your question, I'm looking to see the domain descriptions displayed when viewing the fgdb view data (rather than the real data values).
SSWoodward
Status changed to: Open
Thanks for clarifying @AJR
I've moved this back to open to gain support.
AJR
And really, this isn't file geodatabase specific issue.  Domains should be able to be applied to enterprise geodatabase registered views.
