Hi all,
From the Attributes pane in ArcGIS Pro, when multiple records are selected in a feature class, there's a "Select Only Invalid Objects" that can be used to filter the selection to those records with attributes that don't conform to domains.
Is there an equivalent workflow to find features that have attribute values that don't conform to contingent values? I've tested this approach to see if it would include records with contingent value issues in the selection and it doesn't appear to.
Thanks!
There is not an equivalent capability for Contingent Attribute Values. We appreciate the question and will take it into consideration for a future enhancement.
Jennifer
