Joins based on multiple fields
7717
9
12-23-2010 02:07 AM
Status: Open
CharalambosMattheou4
New Contributor III
To join tables using  multiple fields to create a unique sequence where an entity say a parcel can be  unique  identified according to more than one criteria as shown below. This could minimize data redundancy in tables and editing time
0EM30000000CmbA
9 Comments
DEWright_CA
I can't count how many times I needed to join data based on more than a single value to get my view to work. This really would be a great enhancement.
LindaLilburne
Absolutely essential. If one doesn't have write access then one can't do the workaround of combining the fields into a single field.
RichardFairhurst
If the feature classes/tables are in the same geodatabase or directory you can use the Make Query Table tool to do this. http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000006r000000  It only supports an inner join and is not editable without exporting it, but it can do this type of join and handle all relationship types (one-to-one, many-to-one, one-to-many, and many-to-many).  MS Access is faster and supports outer joins, so if you can use a personal geodatabase you can get the result faster in that program if the data is only tabular.  But the Make Query Tool creates features as well as table rows, so it is better than Access in that situation.  Even so, you would be better off using the Make Query Table tool as part of a process for converting the multifield value to a single field join value to get better performance.  Even MS Access performs better and offers more options with single field relationships than with multi-field relationships.
TomazSturm
Absolutly essential. This would make my work faster and easier.
Bud
Here's a technique that might help in some cases:
If we want to edit a table while filtering based on a multi-field join to a table, we could use a subquery and EXISTS:
(in either a Definition Query or the Select By Attributes window)
exists (
    select
        null
    from
        related_table
    where
        --this is the equivalent to a multi-field join:
main_table.event_id = related_table.event_id and main_table.year_ = related_table.year_ )
https://www.techonthenet.com/sql/exists.php
The downside is that the multi-field join via the subquery only filters the rows. We can't use it display columns in the Attribute Table from the related table.
Alternatively, if we want to display columns in the Attribute Table from the related table, we could create a database view that includes the data from both the main table and the related table. And do a multi-field join via SQL in the view.
And either use/view it as-is in ArcGIS (read-only). Or in ArcGIS, join it to original table and edit the table -- while being able to see the columns from the related table.
MiguelMartinezYordan
Please add the Joins based on multiple fields tool. It will be a tool where you will have the main table and the join table, each with the options to select primary, secondary, tertiary, and so on field options so that the primary field from the main table will match the primary field form the joint table and so on. This will eliminate the need to filter values prior to a join when multiple columns are needed.
A good example is when you have a main column with three categories, and a second column with subcategories, bot those subcategories can be repeated between main categories. Let say you have a main column with building names and a second column with apartment numbers. An apartment number 5B can exist in more than one building. But you want to update only apartment 5B from one specific building. That's where the Joins based on multiple fields tool will filter first the building names and second the apartment numbers.
Bud
A last resort option might be to concatenate multiple join fields together into a single string. And then join on that one concatenated field rather than multiple fields.
But that's pretty messy. I my case, I wanted to concatenate a string and a date together in a file geodatabase view. But I couldn't get that to work using the CONCAT() FGDB function.
Related:
Bud
@RichardFairhurst
Good call on Make Query Table.
It's too bad it doesn't let us join on date fields. I wanted to join two file geodatabase tables on SPECIES=SPECIES and DATE=DATE. But I don't see my date fields in the Key Fields parameter picklist, so best guess is date fields are not supported for joins.
Make Query Table — Use date field in join
Bud
A duplicate idea with the same name: Joins based on multiple fields
And Relate using multiple fields
