When labelling using Maplex, I'd like to be able to suppress labels over a given layer in a map document.
At the moment I can only set a feature weight for a given feature. But if I'm given a contour dataset that overlaps a lakes dataset, I don't want to show contour labels over water.
At the moment I've got two options:
- Suppress all labels over the lakes. This doesn't work as I want to be able label my lakes and this option suppresses all labels over my lake polygons.
- Clip out the contours over the lakes. This is time-consuming, especially on large datasets with LOTS of vertices.
What I am thinking would be great is if in the Placement Properties > Conflict Resolution tab there was a check-box to suppress labels over given layers. This would then read in the layers from the Table of Contents and allow you to suppress for certain layers.
I understand this will add to the processing time while labelling, but it gives the user flexibility.
