IDEA: Add function to link Layout Element and Map layer Visibility to Bookmarks.
This idea initially incorporated map layers as well but have moved that as a comment of another pre-existing idea here: Layer Status Bookmarking - Esri Community
I see this working by having a list of checkboxes on a new section of the Element Pane where you can enable Bookmark Linking and set which Bookmarks would make an Element (or group of elements) visible when navigating to the Bookmark. Elements would be turned off when a non-checked Bookmark is selected. Manually moving/changing the map extent would have no further effect.
By extension, this could be connected to the Bookmark type of Map Series.
Bookmark Linking functionality summary:
- If not enabled (not checked), the elements remain as per what you last set them in the Table of Contents (on or off) when you navigate to a Bookmark.
- If enabled (checked), then the layers would turn on when a checked Bookmark is navigated to, and off when an un-checked Bookmark is navigated to.
- If enabled and no Bookmarks are checked, then it would always turn off when navigating to any Bookmark. This could be a useful way of ensuring that "reference" layers don't display on final map products.
I have a layout and am using a series of Bookmarks to focus on different views of a property - an Overview and then 3 Focus maps with more detail. I have Elements in the layout including Statistic boxes (static text as Dynamic text couldn't break down the figures with enough granularity) and other information (i.e. Layout titles, land tenure summaries and locality labels).
You can see in the screenshots below the grouped elements that I turn on and off to suit each Bookmark.
