Make python the default scripting environment
1521
6
08-17-2012 04:34 AM
Status: Closed
NiklasNorrthon
Occasional Contributor III
I propose to change the default scripting environment for functions like the Field Calculator and the Label Expression parser from VB Script to Python.
6 Comments
CoryWilliams
I like the idea, but maybe have the option of selecting a default parser within ArcMap options instead? (or within the ArcMap Advanced Settings Utility). Give the users the options a choice of what they want.
A lot of organisations are probably still using VBS and don't need to migrate to Python.
My users understand the basics of VBS, but if Python was forced as the default, a lot of Panadol would be needed. :)
NiklasNorrthon
Or maybe make ArcMap remembering which scripting environment that was used last time (globally, or in that map document), and set that to the default next time.
JakeKrall
No offense, but I propose VBS to be the primary scripting for all of ArcGIS.  Much easier to use and write code in half the time of Py-thon which is not user friendly at all.
GusMartinka
This seems like the logical thing to do since VB is not even supported if you are running these tools in 64bit background geoprocessing.
DanPatterson_Retired
ShaunWalbridge
Status changed to: Closed
Given where ArcMap is in its product life cycle it wouldn't make sense for us to update this setting and potentially break muscle memory for so many. Python is the default in ArcGIS Pro. Thanks for your contribution to the ideas site!
