Modify/Import Aliases in a batch process...
1299
01-31-2013 03:04 PM
Status: Open
DanielO_Donnell1
New Contributor II
I have hundreds of feature classes each bearing tens-to-hundreds of attribute fields... I critically need the ability to modify &/or import the field aliases for all of them in a batch process.
The aliases could be imported from a stand-alone table containing ROW1=Field Name & ROW2 = Field Alias.
Ideally, it would function as "seamlessly" as a table join &/or domain/subtype import.
Thanks!
3 Comments
JasonBalmut
You could use this tool: Rename Field Geoprocessing Tool (10.1)  It will do aliases as well in batch mode.
MicheleH_DNReply
It would also be good to be able to batch add aliases to feature classes - SDE and file geodatabase.
JessicaJThompson
Yes Please!
Being able to import fields and domains is great. However, manually adding field aliases, and the choice lists for all of the domains seems like a solvable problem that would save everyone so much time!
@DanielO_Donnell1 's recommendation is perfect.
