Navigating Catalog with back arrow
1073
11-10-2021 12:43 AM
Status: Open
IlkaIllers1
Occasional Contributor III
In ArcMap, you can collapse folders/gdbs/datasets by clicking the back arrow anywhere within the folder/gdb/dataset. For example, if a feature class within a dataset is highlighted, the first time clicking the back arrow will make the highlight jump to the feature dataset. The second time collapses the dataset, the third time it jumps to the gdb, the fourth time collapses the gdb, then it jumps to the folder. It always jumps to the folder/gdb/dataset above and, when the back arrow is pressed again, collapses it. This way, you can collapse and open the entire catalog with just the back and forward arrows. This helps navigating the catalog easily.
In ArcGIS Pro, opening folders/gdbs/datasets by using the forward arrow works. However, collapsing a folder/gdb/dataset only works when the folder/gdb/dataset is already highlighted. If you have a dataset with a lot of feature classes and the one at the bottom is highlighted, you first have to navigate all the way to the top to reach the dataset in order to collapse it.
5 Comments
KennethEggering1
I often find myself having to scroll WAY down into a database, and wish to simply collapse the database using the left arrow key (as is possible in ArcMap). The left arrow key will only collapse the database when the actual database is selected, rather than from anywhere within it (e.g. at the bottom of a long stack of Feature-Classes.
I've searched the ArcPro Docs here, but it does not seem to be mentioned. Are there any hotkeys to collapse a database. I have tried CTRL+Arrows, Shift+Arrows, Alt+Arrows, and the same mix with, for example, HOME, PageUp, etc. to no avail.
KevinRathgeber1
Please add this into Pro.  This was such a time saver in ArcCatalog.  As an admin performing a lot of tasks in catalog this is one of those things that just makes life better for us.  This seemingly little thing makes me keep going back to ArcCatalog when I need to do tasks that require a lot of navigation.  I think the goal here is to have people using Pro more and continuing with that migration, but honestly this one is truly annoying.
Pressing back arrow once on an object should take you to the parent level.
Pressing back arrow on a container like a connection or a folder should collapse it.
Pressing again should take you back to its parent.
NickNuebel
I also find myself returning to ArcMap / ArcCatalog for data management tasks and other things requiring lots of navigation, especially in databases or folder with lots of content. This is a big deal to me; loss of features like this keeps me from adopting Pro full time.
NateArnold
Yes, please incorporate left arrow collapse behavior into Pro's Catalog pane.  I use it all the time in other programs with a tree-structure.  Its absence is truly awkward every time I manage data in Pro.
KoryKramer
@NateArnold please be sure to add your kudos to this idea as it helps us prioritize development work. Thank you!
