A lot of users are having difficulty making the jump from VBA to .NET.
Instead of requiring them to download Visual Studio and use add-ins, Esri should provide an option that is more similar to the good old VBA customization experience, leveraging codedom compiler. http://msdn.microsoft.com/en-us/library/system.codedom.compiler.aspx
For the IDE, perhaps one similar to SharpDevelop, within desktop apps.
http://sharpdevelop.net/opensource/sd/
As with VBA, the code modules would travel with the document. Unlike VBA, the same Arcmap singleton used in Add-ins would be provided. This would make it easy to migrate .NET code from the document to the add-in at a later time. I don't think storing code in mxt files is needed - make people use add-ins if they want to share customizations.
Basically, it would be an add-in that is stored within the document, is edited with something like sharpdevelop, and compiled with CodeDom.
Administrators should be able to configure a machine to either allow,alert, or deny running add-ins that are stored in documents.
ArcGIS Desktop is in mature support and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application. See Migrate from ArcMap to ArcGIS Pro for more information. Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
