When one has many features to show in this tiny window, i.e. from big professional database, sometimes it's problematic and takes time to find the one feature class you need. Especially if you see many schemas you need to search through to all of them. If there was a dynamic kind of filter (as a header I guess?) it would be easy to i.e. type the user name to show all tables he particularly owns.
I'am aware that there's a search window, but, in my opinion there wouldn't be a problem if those two functionalities were functioning side by side.
Hello @Bud ,
We have merged your idea, together with its kudos, into this idea thread, since it is about the same desired functionality.
When you have time, could you please add your kudo to this idea, so that you vote won't be lost?
We appreciate your feedback, and look forward to more of your ideas!
It should be working fine in ArcGIS pro, if I understand the question correctly.
All you need to do is to set your geodatabase indexing, this is turned off by default!
Please check it out:
"To index the contents of an enterprise database—which can be resource intensive—you must do two things: add the database to the project with the Add Database command .
and set your indexing options appropriately. At the next incremental index update, the contents are indexed."
Indeed, this would be useful. Much like we can do with ADS (Azure Data Studio) or SSMS (SQL Server Management Studio).
cheers,
tim
