I think when I save a bookmark it should save the data frame value along with the scales and extent. I often use bookmarks when setting up projects that will involve hard copy deliverables. By doing this I am able to edit and work with the data at an appropriate scale and still be able to zoom back to my "layout" extent. If i have to change the rotation either intentionally or accidentally I would like to be able to use book marks to go back to my saved "layout" via bookmark.
Doing some cleanup here. This was implemented with bookmarks in ArcGIS Pro.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/bookmarks.htm
