Turn On / Turn Off features. In ArcGIS for Desktop you selected multiple layers and could turn them on or off... in Pro - no
Closing this idea as it was submitted against ArcMap, lists a number of separate requests, and many of these are now satisfied with ArcGIS Pro.
In ArcGIS Pro, many of the requested points from above are implemented when working with multiple layers. In general, if you highlight multiple layers, commands that are not available are grayed out while commands that are available to work on multiple layers are active.
For anything that is still lacking and is important to your work in ArcGIS Pro, please search so see if an idea already exists and add kudos and your use case in the comments. If not, follow the submission guidelines (one submission = one idea) to submit a new idea or ideas. Thank you!
