Use ArcPy to Determine Underlying Database
1121
08-28-2014 10:06 AM
Status: In Product Plan
Labels (2)
AndrewChapkowski
It would be nice if the arcpy Describe function would return the database name you are connected to.
For example:
>>> print arcpy.Describe(r"c:\temp\scratch.gdb").databaseName
File Geodatabase
>>> print arcpy.Describe(r"c:\temp\someconnection.sde").databaseName
Oracle
PostGRESql
etc...
This would really help in developing the slight SQL differences between databases in handling of specific datatypes.
Thank you
2 Comments
MatthewYager
For your examples you could craft a routine to tell you this information
anything ending in a gdb will be file geodatabase
do a describe on a sde connection and look at the instance will tell you that database it is based on the connection string  e.g.
  • sde:sqlserver:svr-gis-01  is SQL server
  • sde:oracle11g:GISDATA  is Oracle 11g
desc = arcpy.Describe(Database Connections\Localhost SQL.sde)
cp = desc.connectionProperties
print cp.instance
The only issue I see are the old style SDE connection where the instance will be a port number.
HannesZiegler
Status changed to: In Product Plan
We're working on this!  This status does not guarantee that the functionality will be in the next release, but development work has begun. Release cycles vary by product so make sure to check the product life cycle information to get an idea of when to expect the next release.
