ArcGIS Pro 2.9.5; Oracle 18c 10.7.1 EGDB:
I want to copy an annotation FC (and all it's related FCs) to a file geodatabase. I want to do this in a model, not via copy/paste in Catalog.
Any data dependent on the input is also copied. For example, copying a feature class or table that is part of a relationship class also copies the relationship class. The same applies to a feature class that has feature-linked annotation, domains, subtypes, and indices—all are copied along with the feature class. Copying geometric networks, network datasets, and topologies also copies the participating feature classes.
It looks like the Copy tool can't copy to a different workspace, unlike copy/paste in Catalog.
ERROR 000979 Cannot copy between different workspaces.
Could the Copy tool be enhanced so that data can be copied to a different workspace? For what it's worth, the documentation doesn't mention this limitation. https://pro.arcgis.com/en/pro-app/2.9/tool-reference/data-management/copy.htm
Use case:
