Vertical Center for a Rectangle text element in a layout for a "Title"
1042
12-29-2022 02:17 PM
Status: Open
RyanBohan
Occasional Contributor III
Add the ability to a Vertical Center a Rectangle text element in a layout.
Currently the Vertical alignment is disabled (BUG-000121263), it seems the eyeballing the Offset Y is currently the only option to try and Vertically Center text.
My goal is recreating the following layout.  Having the Vertical alignment would allow a second line to added in seconds, instead of trying to readjust the Offset Y.  Border and background added to Rectangle text element
2 Comments
wayfaringrob
Thank you for posting. I am astounded that the market leader in desktop GIS does not provide a simple way to align text in a box. It results in a lot of eyeballing in layouts which can look very unprofessional and I often end up using another application to do things properly.
Related: Allow Rectangle Textbox to Grow/Shrink and Vertica... - Esri Community
And this closed idea from 2011 requested the same thing: Layout Text Enhancements - Esri Community
MichaelDavis3
Would also love to see ESRI address this.  We have plenty of use-cases where we need dynamic text in map series to be aligned to the bottom of a text frame.  The fact that we can't do this in Pro in version 3.1 is sort of baffling.
