How to set default extensions using Concurrent use licensing
1408
01-13-2021 02:38 AM
ThomasL
How to set default extensions using Concurrent use licensing when starting ArcGIS Pro Intelligence?
In ArcGIS Pro users have to add the extensions (LocateXT, Image Analyst etc.) and reboot the application, this is not very ideal.
Users need a ready to use solution, how do I configure this?
RicklynHukriede
@Anonymous User
by Anonymous User
Not applicable
@ThomasL To make sure I'm tracking, are you wanting to enable extension licenses programmatically at the time of install? So, a silent install that enables the (concurrent use) license and extensions so that the app is ready to go the first time the user opens it up?
ThomasL
@Anonymous User we have Concurrent use licensing servers and set the SOFTWARE_CLASS=Viewer parameter when installing.
How to set the default extensions for LocateXT or Image Analyst etc. ?
Or is the regkey workaround suggested here, also a solution for ArcGIS Pro Intelligence?
End users hate to boot up ArcGIS Pro Intelligence, select extensions and reboot ArcGIS Pro Intelligence to start working.
KatyAppleton1
Occasional Contributor II
@Anonymous User Is there a solution for this please? I have the same issue and came across this thread via a search.
