Hi guys, I am adding several dwgs that were made in AutoCAD LT 14. The imported dwg always has zero attributes and does not display on the map in ArcPro. I have used Add Data and CAD to Geodatabase. Both with the same results. No attributes to display. I have also saved the dwg in AutoCAD 18 and tried to import it with the same results. Has anyone else experienced this problem? Thanks.
