Adobe Print
164
04-18-2024 06:32 AM
chood36
Has anyone had an issue when using "Print Map" to PDF where there it doesn't seem to line up in an area? I sent a screen shot of what I'm talking about. The title blocks seem to have a line running parallel through it. You can see it in the Scale section and follow it down.
Print o Map is the quicker way to create PDFs, especially when you are using transparencies with the basemap. Otherwise, you need to export as a .png and then convert to PDF to avoid the grid lines when you go straight to PDF. This would save me a lot of time by not doing the extra step.
If anyone has any suggestions let me know.
Thank you
