I had been using a ArcGIS enterprise 10.8 with PostgreSQL 11 for quite a long time and after a recent update to ArcPro version 2.7.2, i am not able to execute 'Enable Enterprise Geodatabase', 'Create Enterprise Geodatabase', 'Create Spatial Type'.
It gives me the error msg "You must copy the latest ST_GEOMETRY and dependent libraries to the PostgreSQL software location" Although nothing has changed except the Arc Pro update.. I even tried to copy the st_geometry.so file again still the same error..
We are using an ubuntu server for PostgreSQL version 11..
st_geometry.so file is correctly placed in /usr/lib/postgresql/11/lib
When i create a new enterprise geodatabase the database is created along with the same error but its not a enterprise geodatabase.
i have attached the error snapshot.
Note: In my ArcPro installation in Database Support there are no files for Postgresql. I had copied the st_geometry.so file from my Arc Server instance.
Any help in this regard would be highly appreciated..
Regards,
Nilesh Valwaikar
