Hello all!
I am currently facing an issue related to use aliases in the attribute table. There are some filed created by Near Tool such as NEAR_FID, NEAR_DIST, NEAR_FROMX, etc.
I want to change aliases of those fields from, for example, NEAR_FID to NEAR_FID_Elem so that I could easily join tables without making any confusions. However, the problem is that I cannot save my alias! I changed the alias and it seemed to be adjusted, so I saved the edits. For some reasons, I removed from the table of contents and reload it from file geodatabase. When opening the attribute table after reloading, the changed alias got back to the original one!
I am wondering if this happens just for the fields generated by the geoprocessing like NEAR in this case, or it happens everytime I reload from the file geodatabase.
Thank you!
