I am pretty sure the Alter Field tool had the ability to switch a field from Non-null to Allow Null field property in the past. But the check box for it is now missing. I am using version Pro 2.2.3. Where did it go? Any help is appreciated. I don't want to have to reconstruct my feature class if I don't have to.
Thank you,
according to the help, the table has to be empty to change that property
My feature class has no data or records in it.
I guess a picture will show what is needed. There is only one field there that is 'nullable'
Hmm. Odd. It is now showing up after I upgraded to 2.2.4. I still don't know why the checkbox for 'IsNullable ' didn't show up before though.
Thanks for your help anyway!
Your image shows nothing selected or input, hence the option wouldn't show.
I did that screen in Pro 2.2.3... and I just updated to 2.2.4 and it is still there. Not the update, it is a sparse one and not related to your issue.
It wouldn't be there if there were no fields that were nullable like OBJECTID, SHAPE and its incarnates.
If there is a nullable field it appears, but disappears if you select a forbidden field.
