Dear community, I have a problem with some global Id's. I am working with a SDE database. Now I had to add some attribute rules with arcade expressions for a table. For this reason I had to generate some global id's. The problem is, since I added these ID's, it is not possible to add new features from other datasets. Regardless of whether they also have Global ID's or not. I have run some minimalized examples with or without Global ID, with only two fields in the source table or all the same fields as in the target fields.I also checked the environment settings in the Append tool and flipped the switch to keep the object ID's. But nothing worked.
I always got this error message: " 000597: Failed to insert input record with FeatureID <value>". I hope someone has a solution for this problem. Thanks a lot.
