Arabic numbers in an ArcGIS Pro layout text element
939
09-03-2020 04:37 AM
ahmedmohsen
Am trying to show the arabic numbers in an Pro 2.6 layout element text, the text internationalization settings is all set and well defined
Right to left and Region is Arabic, still my text is not affected at all
the text in the Format text pane seems to be appearing correctly but not the layout display screen it still english.
I have attached an image for clarifications
Any help ?!!
ahmedmohsen
In case any one is having the same problem, I had a workaround and it was editing the font file itself to have only the arabic numbers instead of the english numbers and re install the font into windows then I used the font specially for the arabic numbers in the layout
MoMohamad
Hello @ahmedmohsen , can you explain how to edit font file And to install in win ? I have same problem in ArcGIS Pro
