ArcGIS Pro 2.1.2 Stopped Working on Import Map
1312
6
03-02-2018 01:18 PM
KarenFolger
Occasional Contributor II
ArcGIS Pro 2.1.2 is crashing when trying to import 10.5.1 mxd. It's not a very complicated mxd - with only vector feature classes. But there are several and from various sources. Anyone else having this problem? It just gives a generic message - "ArcGIS Pro has stopped working". Is there any log files anywhere that might explain why?
DanPatterson_Retired
Not an intelligible log file.
Does the error occur with that one mxd or all of them?
KarenFolger
So far just this one. I suspect it's because there is data from multiple projections. I used it in Arcmap to make a map package. I wanted to test that functionality in ArcPro.
KarenFolger
No - multiple projections are not the problem, I just changed them to the same one and got the same error. Data is from various sources however, including SDE, but this data has imported in other projects. I will try to create a new MXD and see if that helps fix the problem.
Also - not sure what you mean by "Not an Intelligible log file". I didn't attach anything - I was looking for a log file of some kind. Maybe you meant there wasn't an intelligible log file that exists?
I meant nothing in the file that would be of any use to people
KarenFolger
It was just that one mxd. I recreated with all the same data and it worked. Weird.
glad it worked out at least
