ArcGIS Pro 2.8 - Deep Learning with GPU - Fatal authorization error
10502
29
05-14-2021 10:14 PM
Tim_McGinnes
Occasional Contributor III
Wanting to try out some of the new deep learning tools in Pro 2.8. I have a clean install of 2.8, cloned Python environment and the deep learning modules installed by "conda install deep-learning-essentials".
I can successfully run the deep learning tools with CPU specified in the environment variables. But when I choose GPU I  get an error box popup: "ArcGIS Pro has experienced a fatal authorization error and must close". Screenshot attached showing error and messages when running the Detect Objects tool.
I have ArcGIS Pro 2.8 Advanced and the Image Analyst extension licensed as a named user through ArcGIS Online. The same thing is occurring on two different machines, desktop with 5Gb Quadro P2000 and laptop with 8Gb GeForce RTX 2080. Both machines on Windows 10.
Am I just too quick off the mark trying to do deep learning in Pro 2.8?
S6
by Esri Contributor
Thanks for the update!
xueyuanyao
New Contributor II
how did you solve the problem?i have the same problem,thanks
S6
by Esri Contributor
hi, install patches 2.8.1 & 2.8.2
xueyuanyao
New Contributor II
thanks,but i installed them,but it doesnt work,i have to use CPU to process it.do you know why?
S6
by Esri Contributor
Are you getting the same GPU authorization error?
Are you using Named-user license or concurrent license?
If possible, share some screenshots.
Shingo-Ikeda
New Contributor III
Could you specify the details of the bug that was fixed for the Classify Objects. I am running into some issues, but I am not sure if they are related.
Shingo Ikeda
Geospatial Data Scientist/Developer - Geographical Information Platform
Global Power Generation - Digital Satellite USA and Canada
samaloysius4
New Contributor III
Hello Shingo-Ikeda,
The Classify Objects tool was taking a long time to run for larger datasets. . The inference process is intensive but it should not take you many hours for a couple of thousand features. This has been fixed in 2.8.2.  We are also looking into fixing an issue with the incorrect progress bar where it shows 100% complete when the tool is still running as well as varying results on different extent runs. That will be fixed shortly. If you are facing other issues please tell us your issue and we will look into it . Thanks.
RobHodder
New Contributor II
Thanks for the information. I have been running into the exact issue with Classify Objects using DL. Looking forward to trying 2.8.2!
S6
by Esri Contributor
I am facing progress bar issues in 2.8.2 as well (Detect objects using deep learning).
SolanaFoo2
I'm in 2.9.2 and when I choose GPU instead of CPU it constantly errors out!
