ArcGIS Pro doesn't show Version Changes between child and Default versions if changes are made in Default Version
964
06-21-2021 11:43 PM
Labels (2)
SrikanthHemadri
I am working on a Geodatabase that has traditional versioning enabled (Option to move edits to base was not used) and created a child version from Default version. Then made edits to the default version and tried to use Version Changes tool in the versioning tab to see the differences between Default and child versions. I am getting the message 'There are no Differences to display'.
Similar activity using ArcMap will show the differences between Default and the child versions. Is there any way to achieve this using ArcGIS Pro?
Thanks in advance.
-Srikanth
MarcelWolf
Same problem here. It worked until 2.8.0
