ArcGIS Pro Labeling
2121
11-03-2015 08:36 AM
JamesPierce
Occasional Contributor II
I just started using ArcGIS Pro today and am trying to recreate a map that I use daily from ArcGIS 10.2.
I am attempting to label some line using a field that contains coded domain values. The problem I am running into is that the label function will only display the code, not the value.  I need to see the value and cannot figure out how to change the display option.
Please help!
Jim
DanPatterson_Retired
Do you have to add the value to the domain? or have you already done this?
JamesPierce
Dan,
The values are already there, I am just migrating the layer over to Pro and symbolizing/labeling in an attempt to replicate the look and feel in ArcGIS 10.2.
The label shows only the code.
Thanks
JamesPierce
Some screen shots to hopefully help.
Domain Table
Note the attribute table showing the lines with the Value listed, not the code.
Note the simple expression I am trying to use in the label class.
