I am trying to display a simple, single-symbology map layer on a legend layout, with the layer name 'LNP Boundary'. When I have both the 'Layer name' and 'Label' boxes ticked in the Element pane for that layer in the legend, the layer name displays fine, as in the screenshots below, where the box is the outline of the legend:
However, I want to display the layer name, not the label. The problem is that whenever I untick the 'Label' box in the Element pane, the label text disappears, but the layer name only partially displays:
I can't work out why this is happening, as there is obviously enough space in the legend to display the layer name. The only workaround I have found is to have both 'Label' and 'Layer name' ticked in the Element pane, and then change the font for the label text to 'No color' to make it invisible. This works, but I would still like to know why I cannot display a layer name without the label switched on. Any ideas welcome.
Yusef
