ArcGIS Pro licensing limitation with hosted feature layer (AGOL)
1707
11-28-2016 03:54 AM
TzurVaza1
I figured that I can't do some work on Feature Layer (Hosted on AGOL) with ArcGIS Pro (version 1.3.1), for example it is not possible to 'add new field' with the Basic licensing level (With Standard or Advanced licensing level it works fine).
I want to know if there are any limitation for ArcGIS Pro with different licensing level (Basic, Standard or Advanced) regarding editing schemas of ArcGIS Online hosted feature layers?
Are there any guidelines or comparison table about what is possible and what is not in any licensing level (on hosted data)?
JoshuaBixby
MVP Esteemed Contributor
I agree the licensing levels for ArcGIS Pro aren't well documented, especially the interface between ArcGIS Online and ArcGIS Pro functionality.  Although this doesn't directly answer your question, and misses some tools newly created for Pro, the licensing of tools and functionality in ArcGIS Desktop (ArcMap) applies to ArcGIS Pro:  ArcGIS 10.4.1 for Desktop: ArcMap Functionality Matrix
RebeccaStrauch__GISP
I agree with Joshua, not much specific functionality matrix for Pro yet....some of that might be because not everything is ported over to Pro from Desktop yet, but I would guess if a Basic/advanced is needed in Desktop, it will be in Pro too.
For any particular tool, you can always find this info on the bottom of the topics help page
Some additional resources re: various ways to license (i.e. allocate):
Licensing ArcGIS Pro—ArcGIS Pro | ArcGIS for Desktop
More Licensing Options for ArcGIS Pro | ArcGIS Blog
and a wiki page that I hadn't looked at before, but I found interesting..
Field Guide to Esri Licensing - GIS Wiki | The GIS Encyclopedia
JayJohnson2
I would suggest reading the release notes:
Release Notes for ArcGIS Pro 1.3—ArcGIS Pro | ArcGIS for Desktop
I went to look up an error message and ran across a list of them, they may give you some insight into what is not yet possible in ArcGIS Pro.
https://pro.arcgis.com/en/pro-app/help/editing/message-services-of-this-type-cannot-be-edited.htm
Data type messages
Workflow messages
JayJohnson2
AniketD
New Contributor II
We can also check this similar thread: ArcGIS Pro Functionality Matrix - Esri Community
