I'm generating an ArcGIS Pro (Version 3.1.3) Project template with many layers preloaded from an Oracle database. When I use the template, everything works as expected. I'm prompted for my credentials once and only once when loading the template. However, my colleagues when using the template are prompted to enter their credentials for each layer, which quickly becomes untenable.
I'm hoping to figure out how I can generate a template which prompts users for credentials only once.
I've tried not entering my credentials, intentionally breaking the layer sources and then creating a project template from there. However, ArcGIS will not let you package a template with broken sources.
