Hi everyone,
I have an enterprise 11.1 deployment that I am publishing to with ArcGIS Pro 3.1. I have published a set of layers (with global ids, archiving enabled and feature access). The publishing process creates a Map Image Layer and a Feature Layer item in portal and I use the feature layer item to create my webmap. I want to overwrite the symbology of one of my layers and I've update the symbology in ArcGIS Pro. I tried Overwrite Web Layer tool to overwrite the layers and the arcgis server end point reflect the new symbology but however my webmap doesn't. Upon looking into the JSON, I discovered the symbology is embedded in the Feature Layer portal item and the webmap pulls it from there. The Feature layer item in portal doesn't seem to update with Overwrite Web Layer tool. I tried updating the Summary, tags, permissions during the overwrite hoping it'd update the portal item but it doesn't seem to be updating. Can anyone suggest a way where I can update symbology without having to recreate these layers in Portal? I know Webmap has the ability to update styles but that won't be a good solution for me.
Edit - I am using Referenced Layers and not hosted layers.
