Hello!
Disperse Markers tool in ArcGIS Pro (Disperse Markers—ArcGIS Pro | ArcGIS Desktop ) edits the geometry of the data, when the data is being scattered (as opposed to ArcMap, when it was used with Representations and the geometry was not affected). Our customer would be interested in a workaround/different way to scatter the points (so that the point features are scattered around, but the geometry is not changed).
I have only found this blog Using Disperse Markers in ArcGIS Pro, which suggests to only work with the copy of the data, so the original geometry is not lost. I would be interested, if anyone knows/uses a different workaround/way in ArcGIS Pro, that would allow to disperse overlapping point features in ArcGIS Pro, while the original geometry is retained?
Thank you!
Soňa
