ArcPro legend layer transparency
3770
10
02-07-2018 06:02 AM
NigelBerjak
Occasional Contributor II
Is there a way to turn off the simulated symbol transparency in the legend? In ArcMap it is done simply via the dataframe properties via the 'Simulate layer transparency in legend' checkbox, but I've looked everywhere and I cannot locate it in ArcPro.
Nigel
NigelBerjak
A workaround is that if you have an image, or non-transparent base layer, you can make a 'legend' set of layers below this, with no-transparency. You keep all of these on and because they are below the base layer, they will not display on-layout. They can then be added to and display without transparency in the legend. Not an ideal, but at least the legend then maintains its link to the main map without having to convert to graphics etc, which I have never found overly useful.
Hope this helps.
