ArcPy Calculate Field Codeblock Error using VB
564
08-28-2023 08:38 AM
JosephPilkington1
Getting an ExecuteError: ERROR 999999: Error executing function. 99.9% positive the error is in my code block. I know, I should use python, but we are keeping the script consistent with VB. For the life of me I cannot see what I am doing wrong. Probably a quotation thing. I have a real problem with that. Lol. Any help is forever appreciated.
# Feature Layer Variable:
TaxParcel_Layer = "TaxParcel_Layer"
# School District Codeblock Variable:
SCHOOLDISTCodeblock = """
Dim X
if ([TaxParcel_INT.SCHOOLDISTNO] = "0091") Then
X = "ALMA CENTER SCHOOL DISTRICT"
elseif ([TaxParcel_INT.SCHOOLDISTNO] = "0476") Then
X = "BLACK RIVER FALLS SCHOOL DISTRICT"
elseif ([TaxParcel_INT.SCHOOLDISTNO] = "0485") Then
X = "BLAIR-TAYLOR SCHOOL DISTRICT"
elseif ([TaxParcel_INT.SCHOOLDISTNO] = "2009") Then
X = "GALESVILLE-ETTRICK-TREMPEALEAU SCHOOL DISTRICT"
elseif ([TaxParcel_INT.SCHOOLDISTNO] = "3428") Then
X = "MELROSE-MINDORO SCHOOL DISTRICT"
elseif ([TaxParcel.SCHOOLDISTNO] = "4186") Then
X = "OSSEO-FAIRCHILD SCHOOL DISTRICT"
elseif ([TaxParcel_INT.SCHOOLDISTNO] = "4368") Then
X = "PITTSVILLE SCHOOL DISTRICT"
elseif ([TaxParcel_INT.SCHOOLDISTNO] = "5460") Then
X = "SPARTA AREA SCHOOL DISTRICT"
elseif ([TaxParcel_INT.SCHOOLDISTNO] = "5747") Then
X = "TOMAH AREA SCHOOL DISTRICT"
elseif ([TaxParcel_INT.SCHOOLDISTNO] = "6426") Then
X = "WHITEHALL SCHOOL DISTRICT"
end if"""
arcpy.CalculateField_management(TaxParcel_Layer, "SCHOOLDIST", "X", "VB", SCHOOLDISTCodeblock)
DanPatterson
def school(fld):
    """specify the field name as"""
    if (fld == "0091"):
    elif (fld == "0476"):
    elif (fld == "0485"):
    elif (fld =="2009"):
    elif (fld =="3428"):
    elif (fld == "4186"):
    elif (fld == "4368"):
    elif (fld == "5460"):
    elif (fld == "5747"):
    elif (fld =="6426"):
    else:
        X = "no clue"
    return X
you can begin with a more literal translation, although there are better data structures that could be used in the code block (eg a dictionary), but this should get you started
... sort of retired...
DanPatterson
You have posted this in ArcGIS Pro place, hence, supported CalculateField languages include
Python, Arcade, SQL
Calculate Field (Data Management)—ArcGIS Pro | Documentation
JosephPilkington1
Any python3 scripting suggestions under this scenario?
DanPatterson
def school(fld):
    if (fld == "0091"):
    else:
        X = "no clue"
    return X
JosephPilkington1
THANK YOU! Worked like a charm! 🙂
