Assign domain to field for a network feature class fails and shows “The domain is required by the utility network and cannot be modified.”
733
10-31-2019 01:52 AM
AlaaFlaifel
"Assign domain to field for a network feature class fails and shows “The domain is required by the utility network and cannot be modified.”"
Assign domain to field for a network feature class fails and shows “The domain is required by the utility network and cannot be modified.” Although the network topology wasn’t initially enabled and there is no domain assigned to that yet.
What could be the issue here?
Best,
Alaa
Tags (1)
KoryKramer
Esri Community Moderator
ALIAZZOUHRI
When an attribute domain is associated with a table or feature class, an attribute validation rule is created in the database. This attribute validation rule describes and constrains the valid values of a field type.
AlaaFlaifel
Thanks for the answer Ali.Can we edit these rules?
ALIAZZOUHRI
Sorry I just saw the comment , yes you can
