ArcGIS Pro does not seem to have the same behaviour as ArcGIS 10.3, with regard to toggling the visibility on/off (simultaneously), of a layer and its corresponding annotation.
I have 2 layers in the table of contents for a map in ArcGIS Pro 3.0.
One layer is a geodatabase feature class of Polygons. The other layer is the annotation feature class (from the same geodatabase) that is annotating the polgons.
In previous ArcMap 10.x, when un-ticking (turning off visibilty) of a layer in the TOC, its corresponding annotation layer would also be automatically turned off. This property was set in the annotation layer's display properties dialog (See attached screen shot). This functionality does not appear to exist with ArcGIS Pro.
Am I correct or is there another way to do this ?
