I have attached a photo from a geodatabase table and linked it to the corresponding file geodatabase feature using a global ID and use it to generate the ArcGIS report. However, when I generated the ArcGIS Report for attribute and image attachments, the photo attachment only displays with the content type "image/jpeg," and not for "application/octet-stream." I suspect that the "application/octet-stream" content type needs to be converted to "image/jpeg" in order to properly display the image in the ArcGIS report. Do we have any solution for converting the content-type in the file geodatabase table ? Or any viable solution. Thanks.
