Hey all, I've been using Pro for quite some time but recently after an update (now using 2.7.2) I am having issues with attachments and joins. Layers that have a join no longer are able to have an attachment, saying ' ERROR 001400: Only the data owner may execute enable attachments.' when I try to enable or attach anything. To be clear, I am the data owner of both files and prior to the update this was no issue and in fact was able to use these same files. I can even enable and add attachments to the two layers seperately, but once they're joined the attacment (and all ability to add one) disappears. This is the case for all of my files, not just one or two. I've tried to use the 'Change Priveleges' tool to make sure everything is in order, which it is.
So is this a weird bug, and has it happened to anyone else?
Does anyone have a suggestion for how it can be fixed?
Cheers!
