Does this happen to anyone else? The Ribbon Tabs automatically switch. I tend to spend most of my time in the 'Edit' Tab, but ArcGIS Pro will switch me back to 'Home' or 'Insert'. Pro usually switches back to 'Home' when first starting the application, and switch to 'Insert' if I am adding and removing features, especially imagery. The switching tends to happen unexpectedly, which makes capturing the phenomenon somewhat difficult.
You can see the tabs switch at the 00:51 seconds mark.
This video is just one example of one scenario where this happens to me. I generally experience this bug at least once per instance of opening Pro, which I do several times per day.
Case Number: 03107517
