Basemap missing when exporting layout to pdf
1182
09-14-2022 06:34 PM
AlexM
New Contributor III
Hello,
I'm using ArcGIS Pro 2.8.6 and trying to export my layout to pdf.
My layout is 55x42" and includes World Imagery Map Service layer.
This layer fails to display in the pdf output no matter how low resolution I've set at pdf export.
Can you advise if it's possible to export the layout with the imagery basemap?
I've attached the export settings.
Thanks
JohnWatt
Hi Alex. I quickly tested exporting an Architectural E size layout with World Imagery basemap. It worked, but produced a very big (slow) pdf.  Some things to try: export as image, dial back the raster resampling, clear the local cache (options\display), write output to a local drive, try a smaller layout.
JohnWatt
