Hi Forrest, welcome to the community forum.
The bug you have listed has a final outcome - ArcMap had a known limitation where certain antivirus software caused the behaviour.
You may be seeing the same issue in ArcGIS Pro. If so, it could be the same limitation, and you would need to work with your anti-virus software provider.
If you want to know if there is a defect for this issue specific to Pro, or just generally confirm it's what you are seeing, your best bet is to contact technical support. They'll be able to search for a new bug number or create one as necessary. If it exists they'll also let you the status/outcome.
Cheers
