I want to create a tool which be capable to read the feature's name with python's expression so I add Parse Path to the feature and add the Calculate Value tool in model builder flow with this command line.
Expression: Name == '%Name%'
Code block:
import difflib
Name=='%Name%'
def funcao(Name):
n = 1
cutoff = 0.8
lista = ['hid', 'hidrography']
close_matches = difflib.get_close_matches(Name, lista, n, cutoff)
while len(close_matches)>=1:
return True
else:
return False
Although the syntax is correct, the expression doesn't work because the result value is not what I want.
My desire was after this Calculate Value results the correct value i will link to If Value is (Value test) and then it would be possible branching the process.
Any suggestions and corrections are welcome!
