Can ArcGIS Pro convert Ground coordinates to UTM?
763
02-12-2020 02:57 PM
Mark_Hotz
Occasional Contributor II
I have an AutoCAD drawing in ground coordinates and need to get this into a usable projection to use in ArcGIS Pro. Is ArcGIS Pro able to do this? I have the math that is typically used to do such a conversion (below), but I am not quite clear how to implement this in ArcGIS Pro:
To Transform Ground to UTM Coordinates
Example: Point100 (Ground) 13262.582 m N, 4380.119 m E
1. Shift back to the original scaled coordinate value:
13262.582 m + 6,000,000 m = 6013262.582 m N
4380.119 m + 410,000m = 414380.119 m E
2. Scale Point 100 from the Ground down to the Grid using the CSF:
6013262.582 m * 0.9996899303 = 6011398.051 m
414380.119 m * 0.9996899303 = 414251.632 m
Suggestions?
Thank you
DanPatterson_Retired
Ground to grid correction—ArcGIS Pro | Documentation
but it seems to more for construction tools
Mark_Hotz
Thanks Dan:
I was looking at this tool in ArcGIS Pro, but it seems to want direction offset for one direction, whereas the formula I have requires two...unless I'm missing something:
I was sure that the way to do this was to create a custom projection, but I cannot find much anywhere that explains how to do that.  That and  the direction offset options are dd, dms an ra...whereas the output needs to be in UTM.
I think the problem right now is that I have no idea how to use this Corrections tool LOL.
dd has a drop down arrow is there other options if you click on it (I don't have data to test)
Also there is some mention in
About CAD coordinate systems—ArcGIS Pro | Documentation
Parcel fabric data model—ArcGIS Pro | Documentation
