Can I set Geodatabase and Toolbox attributes with Pro.settingsConfig file?
177
a month ago
tamasoz
I have been successfully deploying Pro with Pro.settingsConfig file, after completed install the values are indeed reflected in the settings how they should and despite of the missing dynamic username insertion routine we are reasonable satisfied with this feature.
There is one thing I cannot find in the documentation though - and its rather trivial. I can set the values of the Default geodatabase and Default toolbox paths fine.
However, I am, not sure if I have any ways/options to set these values of the Application -> General -> Create Projects tab.
I am especially interested to set the "Same default toolbox for all project" and the "Same default toolbox for all project" sections - screenshot attached.
Is this possible to be set via the Pro.settingsConfig file?
Thank you
Tags (1)
