Can I use soil data viewer in ArcGIS Pro?
3121
11-20-2017 08:34 AM
DavidPalacios
Good day everyone,
I'm working on my project for one of my design classes and need to generate a soil map data using SSURGO data to work of for my project. I'm aware in the regular ArcMap, you need to install the soil data viewer add-in. My question is can this extention work in Pro or, if not, then any solution on how I can go about creating the soil map?
Thank you
XanderBakker
Esri Esteemed Contributor
If you are referring to thisAdd-In: Download and Install Soil Data Viewer 6.2 | NRCS Soils  . It states that it is compatible with ArcGIS ArcMap up to version 10.3. An Add-In for ArcMap is based on ArcObjects and not compatible with ArcGIS Pro. I also noticed something depending on MS Access and ArcGIS Pro does currently not support Access either.
Maybe it is best to contact the USDA to see if they have any plans to port the Add-In to ArcGIS Pro or to change the data format.
JoeFlannery
Occasional Contributor III
David:
Are you aware of the SSURGO data available in Esri's Living Atlas?  These online data can be used in ArcGIS Pro.
http://landscapeteam.maps.arcgis.com/apps/MapJournal/index.html?appid=e5148c75efb04d06b65ab10446060c...
SheriNorton
I spoke with a representative from NRCS last year and was told that a version of Soil Data Viewer for Pro would be released this year sometime (2024).
Alena
New Contributor III
They are not creating a Soil Data Viewer for Pro. It will work independently in a new product called SSURGO Portal.  SSURGO Portal is a license free application that allows you to import spatial and tabular SSURGO data into geospatial SQLite SSURGO template databases. There is a ton of info on the webpage, and I recommend reading it all the way through. It provides additional resources.  Check out the quick start guide at the top if you want to dive right in. There are Bulk Downloader tools for ArcGIS Pro and QGIS to download several datasets at onetime from Web Soil Survey. You can create your own SQLite database at any size in SSURGO Portal with the spatial data and tables.  The SSURGO On-Demand application replicates some of the same aggregation as Soil Data Viewer. It will create a table in the SQL database that can be joined to the spatial data by MUKEY. The Soil Data Viewer for SSURGO Portal won't be released until 2025 or the earliest late 2024.
