Hi, I'm newish to ArcPro (long time ArcMap user) and I'm having trouble figuring out if this is a thing:
I have a layout with two map frames: the main map and an inset frame.
I want to link the inset frame's center and scale to the main map. BUT, I don't want the inset to have the exact same scale as the main map, I want it to be a proportion or relatively linked to the main map.
For example I want to be able to have the inset map zoom in, in proportion to how much I zoom in on the main map, but not match scale exactly. I want to be able to set the inset map to be 3 times the scale of the main map, or 100,000 more than the map, so that if the main map is at 1:30,000 and the inset map was at 1:300,000 and I zoom in the main map, to 1:20,000, the inset map would then be 1:290,000 or 1:200,000.
Either way (proportional or relative) I would be happy with, I just want both to zoom in at the same time, just not have both frames have the exact same scale, which seems to be the only scale-linking option in the constraints drop-down. Is this a thing?
