Change default split policy on new domains?
5918
25
02-06-2020 08:22 AM
AnnaRoyar1
Hello!
I am having to set up a bunch of new domains a day for the foreseeable future. Is there a way to have the split policy in domains automatically go to "duplicate" instead of "default" in all new domains. We NEVER need the "default" option and it is very easy to miss that step when setting up multiple things per day.
LukeGilner1
Thanks for looking into this Lindsay.  I was hoping I was doing it wrong!  I'm surprised there are not more people screaming about not being able to update the definitions in the admin services.
Overwriting all my services would definitely not be ideal.  I might just have to revert back to Pro 2.8 just so I can use my split tool correctly, until they fix things.  I'll try to follow up with ESRI about the bug that didn't really get fixed.
LindsayRaabe_FPCWA
Idea posted here: Update "Alter Domain (Data Management)" tool to up... - Esri Community
Lindsay Raabe
GIS Officer
Forest Products Commission WA
Cebrown2206
I'm not sure if there's an answer to changing the default settings...but I run a pretty standard script to do this whenever I start a new project and need to make edits to data. You could employ the same script and schedule it to run daily to update all the domains you create.
Hopefully this helps.
# Identify all domains present within the gdb and create an object list
domainList = arcpy.da.ListDomains(inputGDB)
# Update the split policy for each domain within a loop
for domain in domainList:
# Identify the domain name from the domain object list
domainName = domain.name
# Update the split policy to 'Duplicate' for the domain
arcpy.management.AlterDomain(inputGDB, domainName, split_policy='DUPLICATE')
LindsayRaabe_FPCWA
Is your script running on local feature classes or feature services in ArcGIS Online? I'd love to find a way to manage ArcGIS Online domains from centralised lists.
Lindsay Raabe
GIS Officer
LukeGilner1
@LindsayRaabe_FPCWA - I have figured out how to update definitions through the admin services in AGOL!  Here is the general workflow:
1. Go to your item page of the desired layer.
2. Scroll down to the URL and click View.
3. In the ArcGIS Rest Services Directory, click on Admin on the top right.
4. Click on the layer name.
These next few steps are from LindsayRaabe's post here: Re: Splitting tool wipes values from AGOL feature ... - Esri Community
5. Scroll to the bottom of the page and select the "Update Definition" option
6. Clear the lastEditDate value (replace the value with "")
7. Scroll down to the fields list
8. Update any field domains where domain is NOT null with the below line of text:
        "splitPolicy" : "esriSPTDuplicate",
 Updated JSON below:
9. When finished, click the Update Layer Definition button.  You should then say the layer was updated.
LindsayRaabe_FPCWA
I'll have to give this another crack if I can find a feature service that still has the old settings. I think I did a mass run of updates when I had this working the first time so might not have any left. Suppose I could always try on a test dataset and see what happens. Good to know that it wasn't all in vein though!
Lindsay Raabe
GIS Officer
