In ArcPro, when COGOing a curve in a traverse, the default for the bearing is a tangent curve, and to change that to a chord bearing, you need to add cb at the end of your bearing to override the default. In the work I do, I never use a tangent bearing, so I always have to override it. Is there a way to change the default setting so that the default for the curve bearing is the chord bearing?
